ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
ES350 Check VSC and Engine light on. Car Vivrates
Old 05-07-12, 11:56 AM
Hmanan
Hmanan's Avatar
Default ES350 Check VSC and Engine light on. Car Vivrates
Hi,
I am new to this forum and there seems to be lot of information here.
I have a ES350 2007 that just got the Check VSC and Engine light on. I have tried the Gas CAP and that is not it. The car also vibrates between 1400 to 1600 RPM. After 1700 RPM it runs smooth but if the car is at the stop light, it shakes and sounds like it will shut down but it doesn’t.
Any help would be appreciated.
Old 05-07-12, 01:27 PM
garsarno
garsarno's Avatar
This sounds like a Lexus or Toyota dealer evaluation.
Old 05-07-12, 06:41 PM
oldgrump
oldgrump's Avatar
It appears that the engine is missing and the ECM has set a code/s and has illuminated the Check Engine light. The VSC is disabled due to the misfire. Get this looked at ASAP.
Old 05-08-12, 07:08 AM
Hmanan
Hmanan's Avatar
It did get liitle better after I put in Lucas when I filled up gas but do you still think I should take it to Lexus dealer.
Old 05-08-12, 09:07 AM
garsarno
garsarno's Avatar
There will be codes to read for the Lexus technician to read and act on with the light coming on.
Old 05-08-12, 03:34 PM
LexusChuck
LexusChuck's Avatar
Pouring additives into the fuel tank or crankcase rarely solves an automotive ailment. It needs a technician to diagnose and solve the problem. I agree with oldgrump and garsarno.
Old 05-08-12, 05:51 PM
garsarno
garsarno's Avatar
At the very least, take it to a Toyota dealer to save $$ if need be.
Old 05-08-12, 11:20 PM
GS4_Fiend
GS4_Fiend's Avatar
find out what the codes are
Old 05-09-12, 06:37 AM
MadMax96
MadMax96's Avatar
I sure hope you took it in - driving around with CEL especially when the engine isn't acting right can NOT be good. You're possibly making matters worse.
If it was my car I would have parked it and had it towed immediately to avoid any further damage.
Jbakyy
06-02-22 06:59 PM
D.Steezy
07-03-09 12:30 AM
kidluvsole
05-26-08 07:32 PM
06i
01-13-08 07:23 PM
abear2007
Maintenance
03-14-07 02:20 PM
Quick Reply: ES350 Check VSC and Engine light on. Car Vivrates
