ES350 Repair Manual
I am trying to replace the Bank 1 Sensor 1 on my ES350 so I thought it would be a good idea to get my hands on the repair manual for this and any future fixes.
Hello,
I started my car yesterday morning and "check VSC" & "check engine" lights came on the dash board. For over 24 hours now, the light is still on. I have tired to reset the car with from the Dash board but the light refused to go off.
How can I remove this light from the dash board? Thanks.
Hello,
What you need is an OBD2 scanner to hook up to the car and pull the codes to find out what's wrong. You can also clear the lights with the scanner.
You can also go to an auto parts store like Autozone. They have a scanner and will pull the codes for you and clear the lights for free. I will tell you that's not the best idea. Better to just take it in to a mechanic.
Hello,
https://www.clublexus.com/forums/es-...e-stalled.html
Just search "VSC Engine stalled".
Might not be your case, but do some checks.
