2007 Lexus ES350 Sensor Bank 1 Sensor 1
Hello Everyone,
I am new to this forum.
I own a 2007 Lexus ES350 and got a P0031 engine code and wanted to know where the Bank 1 Sensor 1 was located on this model?
Also, what is the correct part number for this so I can purchase this sensor online?
Thanks!
Thanks!
A search would have brought up this thread:
https://www.clublexus.com/forums/es3...en-sensor.html
It's bank 2, but I'm sure it can help you.
Lou
Lou
One piece of info I forgot to mention that when this light first came on I tightened the gas cap and the light went away by itself the next day. However, a few days later it came back on and has been on ever since. Could this problem be due to the gas cap or was the sensor just on its last days?
p0031 code
I should of took a picture of the whole page but my bad but this might help i have the same code on the same car just bought it too the guy i took bought the car from fixed the wrong sensor so i had my mechanic print this out to show the guy what he did wrong.... this picture shows you the front of the engine on as if you are working on it ( the way it should be lol) bank 2 is the front of the engine wrong sensor to fix the code even states bank 1 sensor 1 which is in the back of the engine.
Code p0031 bank 1 sensor 1 .
The P0031 code is referring to the air/fuel sensor.
Info on all ES350 air/fuel and oxygen sensors: https://www.clublexus.com/forums/es-...nsor-info.html
Only use a Denso sensor (or OEM, but they are usually much more expensive). It appears the bank 1 sensor1 is now part 234-9022 and B2S1 is 234-9008.
CactusMatt
ES - 5th Gen (2007-2012)
02-17-15 09:26 AM
