battery recommendation
The best battery is at costco for $120 with 3 year warranty. The brand means nothing, and most important is how fresh battery is. The one I got at costco was 1 month old, their stock is fresh
GVK - you posted in the wrong forum for a 2019. That should be asked in the 7th generation forum.
This is the 5th gen forum for 2007 - 2012 models.
A battery is a battery is not completely true...The 07 calls for a 24 or a 35...Either can be used...If my memory is correct, the 35 has more cold cranking amps than the 24...Both are rated 84 months with three years free replacement ....I just had my 07 battery replaced about four months ago..I chose the battery with the greater CCA....The original battery was 4 and a half years old....Sam's Club installed it FOC and they were able to hook in a power pack which saved all the memory settings..If a power pack is not used, then .the pinch protector for the windows might have to be reset, by taking off the door panel and going thru a procedure to reset the pinch protector...what a hassle...Hope this helps
Wilson2000 (06-06-24)
