My 2007 Passenger window wobbeling
I just bought a used 2007 ES350 and find out that my Passenger window is wobbling, can I fixed it myself? Please help.
Thanks
Darkman67
Thanks
Darkman67
Many posts about his - will most likely fail and the side glass will pop out. Take immediately to the dealer to exercise any warranty you may have. To fix, it costs $800 for the complete assembly and labor.
This is a design problem in the 07 08 side windows...The plastic holding tabs are built into the glass...The plastic will crack and/or break and the window will come off track..The window then sticks off about 4 inches at the top..I had this problem on the drivers side..It was out of warranty and Lexus would not fix it FOC...They quoted me $660...I had a glass shop replace the window at a cost of $220...The replacement glass does not have Lexus etched in the glass (which I can do without)...When a new glass is installed, the pinch protector should be reset as the computer does not retain this feature...I addressed the procedure for resting the pinch protector in another post...Hopefully, your Lexus dealer will replace your passenger side window FOC...Hope this helps....It is a shame to have a LUXURY car that the owner has to be concerned about the windows popping off track...I read in another post that the drivers side window came off track and shattered when he was on the interstate doing 60mph...I believe that a class action suit might be the only way for Lexus to accept responsiblity.........
Thank you you all, that cost a lot for a windows and that was not very nice customer service of Lexus, i had Nissan and Infinity for almost 18 years now and never had that kind windows problem may be this is my first and last Lexus. I think i will stay with Infiniti then.
Anyway, thanks you all bery much
Kim
Kim
