ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Low tire pressure lights 2007 Lexus ES350
Old 08-22-12, 05:00 PM
SAGES350
SAGES350's Avatar
Angry Low tire pressure lights 2007 Lexus ES350
Any help on how to reset the low tire pressure light on 2007 lexus ES350. it is driving me nuts after checking all correct tire pressure the light is still on.
Old 08-22-12, 06:10 PM
oldgrump
oldgrump's Avatar
Did you try resetting the system? Hold the reset button (above your right knee) until the tire pressure warning light blinks three times (ignition ON mode), wait a few minutes, and then switch to OFF. If you have a full size spare it has to have the tire pressure the same as the other four. This procedure is in your Owner's Manual under "Do it yourself maintenance......Tires.......initializing the tire pressure warning system" .
Old 08-22-12, 09:41 PM
Received 2,774 Likes on 1,981 Posts
Check the spare, I'll bet you a round of air that's it
Old 08-23-12, 11:31 AM
ashleymari
ashleymari's Avatar
You're in Wisconsin. You might be experiencing the same weather we have. (We're in the suburbs of Chicago)
It might be the fluctuating weather. My tire pressure light was on this past week due to the extreme temperature changes. We went from 90's to 70's with low 60's at night and early mornings to mid 80's in the afternoon. That caused my car and my mom's RX tire pressure lights to go on. Since it's been consistently warmer the past couple of days, mine finally went off.
Old 08-23-12, 12:57 PM
retired
retired's Avatar
Had the same problem....I inflated all 5 tires (the four on the car and the spare) to 35 psi... Started the car and the light went off...I then lowered the pressure to the recommended 30 psi except for the spare...I left it at 35 psi....The warning light did not come back on when i restarted the car......Remember to do this when the tires are cold (first thing in the morning is best) ..Hope this helps...
Old 08-23-12, 05:12 PM
SAGES350
SAGES350's Avatar
Thanks for all who have respnded to my post. I really appreciate your assistance.
Old 06-27-18, 02:43 PM
panocean
panocean's Avatar
Default Lexus es350 2007
LEXUS ES350 2007 low air pressure light is on all tires have right pressure
how do I remove this light any help
Old 06-27-18, 02:44 PM
panocean
panocean's Avatar
lexus lx570 2013 hard to shift gears particularly when truck sits for a while
any one facing same problem
any solution?
Old 06-27-18, 04:08 PM
jagtoes
jagtoes's Avatar
Just an FYI to all who are not aware . The battery in the TPMS in each wheel is usually good for 5-7 years. So if one or more of the batteries are bad you can't erase the light on the dash until you replace the TPMS. Go to any tire shop and ask them to check the sensors . It should take about 10 minutes to check 4 or 5 tires.
Old 06-27-18, 05:56 PM
12jimmyjam
12jimmyjam's Avatar
Do they use an external sensor to test them? I have that issue now-repeated blinking and then steady light.
Also, are aftermarket sensors ok? I just shelled out $900 for new Michelins and an alignment.
Old 06-27-18, 07:53 PM
jagtoes
jagtoes's Avatar
I have a tester and it is non contact and used by placing it next to the tire stem. It reads air pressure and temp and battery status.
Old 06-28-18, 09:52 AM
panocean
panocean's Avatar
OK
great I ll try
thanks
Old 06-28-18, 03:34 PM
BigPapa53
BigPapa53's Avatar
Our TPS light has been on since we bought the car a few weeks ago. All the tires are set properly, including the spare, and I have reset the system. Funny thing, my boss told me that he bought an '09 ES350 new and that it was one of the best cars he'd ever owned. He told me the only problem I'd have was the TPS sensors.......
I'm going tomorrow to have the tires rotated and balanced and the sensors tested to see which one's bad. I'll report back.
Old 06-30-18, 05:25 AM
BigPapa53
BigPapa53's Avatar
Well, I had one bad sensor.
Old 06-30-18, 06:50 AM
Dave Mac
Dave Mac's Avatar
I see several of these testers offered - can you tell me which one you have that works well? Thanks.
Dave Mac
Quick Reply: Low tire pressure lights 2007 Lexus ES350
