ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
How to default NAV screen from map to audio view
Old 08-30-12, 09:35 AM
provlima
provlima's Avatar
Default How to default NAV screen from map to audio view
When not using the NAV I usually listen to the radio options.
When I choose an option, lets say satellite radio, a short time later the screen reverts to the NAV map screen. Is there a setting which allows me to change the screen from switching from the audio to the map mode?
Thanks for your help!
Old 08-30-12, 02:20 PM
Blueshark
Blueshark's Avatar
As i remember, you can choose on the opton menu that the screen return to the nav automatically or not.
Old 08-30-12, 03:46 PM
garsarno
garsarno's Avatar
There is that option on the menu. I change back and forth, seems I like to revert back to the Navigation screen. Then a few months later, I switch it so that you need to manually switch it. Can't make up my mind.
Old 06-21-18, 12:08 PM
kodavis
kodavis's Avatar
I am aware that there is an AUTO setting that you can turn off to keep the display from automatically switching to the navigation map while driving. However, the issue I have is that the screen keeps switching back to the map after changing gears. For example: I can have the screen on audio and then switch the car to reverse to back out of my driveway. The backup camera turns on but after switching back to drive it displays the map instead of audio which is the last screen I had it on. Does anyone know if there is a way to change this?
Old 06-21-18, 12:14 PM
mjeds
mjeds's Avatar
the only way to keep it in audio mode is to have it in audio mode when the car shuts off.
if you are on the "home screen" or any other screen when you turn off the car, it will revert back to the map.
if you are on the audio, be it AM,FM, USB, Bluetooth, screen, it will startup on that screen.
Old 06-21-18, 12:29 PM
kodavis
kodavis's Avatar
The issue I'm having isn't with startup. It's when going from Reverse back to Drive. No matter what screen I had it on previously it seems to go back to the map. Does anyone else's unit behave this way?
Old 06-21-18, 12:32 PM
mjeds
mjeds's Avatar
sounds like the auto-switch is turned on.. FWIW that feature always reset to "on" when I had a dead battery, or a software upgrade done to my car.
Old 06-22-18, 11:10 AM
kodavis
kodavis's Avatar
The auto function is OFF but it still happens. I guess it is just a minor quirk I'll have to live with.
Handi
01-18-17 12:11 PM
meka2u2
ES - 6th Gen (2013-2018)
06-27-14 07:36 PM
JohnS
09-15-11 08:50 AM
cal007
HS 250h Model (2010-2012)
08-01-11 10:01 PM
sabucat
05-18-07 04:53 PM
Quick Reply: How to default NAV screen from map to audio view
