Broke My Mirror
So while I was going through the car and changing out bulbs, I got to the first mirror and it was giving me hell. I got the mirror itself off (which took some SEROIUS pulling......I thought I was going to break it) and took out the screws. The housing was HELL to get apart. Seemed like it was "stuck" together. I was thinking that maybe it was held together by clips or something of the sorts, so I gave it a little tug, and CRASH!
The lens fell out the bottom, the backing hit the floor, it was a disaster! After some further inspection, it looks as though I was not the first person to work on the mirror. The cover of the light assembly was super glued on, and I imagine that was what was holding the mirror back and front together. I got the light assembly out, and re-glued the cover on it, changed out the bulb, and put the housing back together. it was a little challenge to get it to line up, and get that broke-daddy light assembly all to line up. Then came getting the mirror to "snap" back on to the backing. I put the top clips in first, as they slide in, and then tried to snap the bottoms in after that. I was really having to push, and from my previous experience, I was trying to be gentle and not break anything else. I grabbed a flat head screw driver and was trying to hold the back plate while applying pressure to the mirror......then SNAP, cracked the effing mirror in half. It didn't break, but cracked the length of the glass.
Wonder if the Camry mirror would work..........wonder what Lexus wants for one.........
Called a local glass shop, and they quoted me for a cheap piece of crap that was not auto tint and not heated.......I asked if they had a factory replacement, they said contact the dealership.......I can't wait.
Definitely not interchangeable, the Camry and ES have completely different mirror shapes/designs.
got a used factory replacement on ebay for 75 bucks. I guess there were sizes??? Anyway this one matched the measurements that the guy gave in the description. Will post results when she comes in!
The 2007 mirror was larger, the size was reduced in 2008. Not sure if the glass is the same from 2009 to 2010 since they added the signal mirrors, the shape of the mirror changed a little.
Well I got the mirror in and added some bulbs in the lights. The new mirror went in smooth as silk. I got these bulbs from V-LED's and they were CRAZY long....
http://www.v-leds.com/5K-WHITE-4-LED...25900-1-2.html
So I went back at it with the Dremmel. I shaved some of the wall of the light assembly, and actually shaved a little of the end of the bulb off.after taking about 1/16 of an inch combined, it was still a really snug fit, but it did fit, and they are bright as hell. Kinda hard to tell from the pic, but it is a HUGE improvement.
![](http://i139.photobucket.com/albums/q295/chef_choy/IMG_00921.jpg)
I later read a better way without using a Dremmel.
Someone posted just heat the light assembly back and stretch it out a bit.A much better and easier way to go.
VLEDs 4 LED flanks were without the heat sink on my last couple of Lexus vehicles.Fit perfectly without any alteration.Too bad VLEDs went to the new bulb style.
Worth the hassle because the LEDs do look great.
mrsardar
02-25-18 11:57 PM
Randre19
01-09-14 07:43 AM
