2010 es 350 tire monitor system
Hi I am new to this site. I have a 2010 ES 350 cannot seem to get the TMS light to go off
when it starts the light blinks then become steady. I had the sending units checked and all 5 are working. Air pressure in the tires are at 32psi. Is there a reset button on this car or do I have to go back to the dealer.
Thanks for any help
Thanks for any help
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
There's a reset button under the dash in the drivers side...
According to the Owner's Manual the warning light illuminating steady after one minute of flashing is indicating a system fault. But......I would try initializing the system (also in your Owner's Manual) by pressing and holding the Tire Pressure Monitoring System reset button (above your right knee) until the warning light blinks slowly three times. The start/stop switch has to be in the "Ignition On" mode and after the light flashes three times leave the car in the "ignition On" mode for a few minutes and then push the start/stop button to go to OFF. There is also a tire set selector button under the glove box door and it's purpose is also explained in your Owner's Manual.
Thanks for any help
Thanks for any help
https://www.clublexus.com/forums/es3...ure-light.html
Lou
kSunflower
CT 200h Model (2011-2017)
04-23-18 07:36 AM
Begood9394
11-01-17 07:55 PM
