tpms light wont go out 2011 es350
i noticed the tire pressure light in the dash was on; i filled all tires inluding spare,but the light stayed on. i followed the steps in the manual but it still stayed lit. i even overfilled tires and still no luck. what am i doing wrong.
Same happened to me on my o7...Had to overinflate all the tires to 36 psi....The light went off and I then lowered each tire to 30 psi.....How, much did you over fill your tires...If this does not work then reset the TSPM....as recommended by another member....Hope this helps
