ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
2011 headlight accent light
Old 02-02-13, 11:20 AM
RTSM
RTSM's Avatar
Default 2011 headlight accent light
Hello forum members, for the 2011/12 model years on the headlight we have a accent light see the attached photo. Does anyone know if this is a separate bulb or is it just using the HID headlight bulb?
I thinking of getting 6k HID's and thought that I might replace this bulb as well if it is separate.
Let me know what you folks have found.
Old 02-05-13, 09:14 AM
jcat_350
jcat_350's Avatar
Can't really tell by the part diagram, but looks like it should be separate from the HID low beam entirely. I cannot find a separate part in the diagram for it. Is it bright white when illuminated or yellowish like a halogen?
If it's yellowish, it may be taking light from the parking lamp above the turn signal, which is replaceable. If bright white, I have a feeling it's LED and integral to the housing, which means it can't be replaced.
Old 02-05-13, 10:37 AM
garsarno
garsarno's Avatar
If it is a yellow parking type light, www.hoenusa.com has yellow light bulbs with a mirror type finish to them but they will still blink yellow. Takes out the "egg yolk" color bulb.
Old 02-05-13, 05:27 PM
oldgrump
oldgrump's Avatar
That's the "parking" light which is an LED. It appears to be part of the headlight "unit". If it dies the Owner's Manual states to see a dealer. When the HID headlamp is lit there is a reflection or glow from that weird, textured reflector under the HID headlight (inboard of the parking light).
Old 02-05-13, 07:11 PM
RTSM
RTSM's Avatar
Thanks all, yes it does look like it is either being emitted as part of the HID lights being directed through the headlight bezel or a dedicated LED light. I tried to look in the engine compartment but I could not decipher a secondary bulb connection. I'll check with the dealer and see what they say and let you all know what I find.
babaliont
05-08-14 01:50 PM
Chekmi21
08-29-13 04:46 PM
b4k4kun
03-08-11 10:32 PM
Shadowen
IS - 1st Gen (2001-2005)
01-04-11 12:59 PM
b3player
10-23-05 06:06 PM
Quick Reply: 2011 headlight accent light
