ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Courtesy Light Color L.E.D Retro Fit. IT CAN BE DONE!
Old 03-09-13, 08:48 AM
SICK350
SICK350's Avatar
Default Courtesy Light Color L.E.D Retro Fit. IT CAN BE DONE!
So today I was pulling out the centre console in my car for another project and I had a idea, I noticed a lot of guys buying replacement courtesy lights in white led for $23 each. With this thread you should be able to do all your courtesy lights in you car for under $5 in any color you want.
I started by pulling out this light from my glove box, this can be done to the glove box, centre console, foot well lights and other dash l.e.d's
Attached Thumbnails Courtesy Light Color L.E.D Retro Fit. IT CAN BE DONE!-image.jpg
Old 03-09-13, 08:50 AM
SICK350
SICK350's Avatar
You twist the light out of the housing and then pop off the top to revel the circuit board and OEM amber l.e.d.
Old 03-09-13, 08:51 AM
SICK350
SICK350's Avatar
Next I cut the old amber l.e.d. out and drilled the light hole a bit bigger for new blue l.e.d.
Old 03-09-13, 08:53 AM
SICK350
SICK350's Avatar
I cut off the capacitor off the new blue led and added a bit of wire for length.
Old 03-09-13, 08:54 AM
SICK350
SICK350's Avatar
I soldered the two connections to the board. (Sorry for the crapy pic it was hard to get a close up).
Old 03-09-13, 08:57 AM
SICK350
SICK350's Avatar
Popped the top back on the light and reinstalled in housing, then plug and reinstall in glove box. I'm going to do all these lights a bright white. I just wanted to see if it could be done and I had a couple extra lights kicking around. The light I used was a t5 l.e.d. Bulb.
Old 03-09-13, 09:02 AM
SICK350
SICK350's Avatar
I also was able to plug the 12 l.e.d. Panel directly into the plug and it worked. You could heat shrink both connections together and stick these panels in most locations for extra light.
Old 03-09-13, 09:08 AM
SICK350
SICK350's Avatar
Here's a close up of the new l.e.d. Installed, looks factory.
Old 03-09-13, 11:41 AM
SICK350
SICK350's Avatar
Here's a before and after.
Old 03-09-13, 12:23 PM
1sWt2GS
1sWt2GS's Avatar
wow that looks good
any installed pics zoomed out?
Old 03-10-13, 05:50 AM
SICK350
SICK350's Avatar
Originally Posted by 1sWt2GS
wow that looks good
I'm just waiting for some white lights to come in the mail and then ill post some installed pics. Thanks for the comment!
Old 03-10-13, 05:59 AM
xanderES
xanderES's Avatar
Very nice DIY and I must say you're quite the crafty one. I never thought of breaking open the housing and replacing the LED's this way. I just ate the overpriced cost of the IS/RX lights.
Good work!
Old 03-10-13, 09:42 AM
SICK350
SICK350's Avatar
Good work!
For some reason I can't just leave things alone lol, I'm always taking stuff apart and playing with it. I started taking all the lights I can find in the car out. If I can change them my self (if I feel brave enough) I do it my self, as for the tiny ones I think I'm going to take it to someone to have done.
I added a link to a thread when I get a lot of info on led swaps.
https://www.clublexus.com/forums/is-...swap-leds.html
Old 03-10-13, 10:11 AM
xanderES
xanderES's Avatar
I thought briefly about the head unit led swap while my dash was out but I think the green leds left in the rear view mirror compass and auto light would drive me crazy.
If you figure out how to modify and retrofit the front or rear interior lightning please let me know!
Old 03-10-13, 10:30 AM
SICK350
SICK350's Avatar
Ill get that mirror light swapped somehow lol, as for the dome lights there also on the list of things to do. There pretty dim. The back one scares me tho. Not sure exactly how to go about removing it.
Quick Reply: Courtesy Light Color L.E.D Retro Fit. IT CAN BE DONE!
