Disconnect of 08 non-ML sub
Quick question ... did you change out your OEM component speakers? If so, how was the quality after replacing them?
The ones in the es 350 '07 non-ML are quite bad.
I am thinking about placing JL CR2's in there, and the stock headunit/amp should be enough to power them I hope.
JL is always a good choice but their price to performance ratio is not the best. My PG components were always rated at one of the best in the $100 range. If I were going the more expensive route, I'd look at CDT, DLS or Dynaudio.
The factory amp does have enough power to drive the speakers when the bass is removed from the signal.
SC400-V8
06-14-05 07:37 AM
CANADAGS400
16
05-16-03 08:54 AM
