Any performance (hp or transmission) mods for the ES?
Hi there, I've done a bit of searching and I haven't found any evidence of any sort of substantiated performance mod to increase power... I do know this isn't a performance sedan, I know that Toyota ecu programing is hard to alter and I also know that the car is pretty powerful as it is... But often there is a bottle neck or two that can free up a few hp, etc.
Just curious to know if there was one? (I noticed the transmission is especially slow to react, anything we can do there?)
Thanks!
Thanks!
Most you're gonna be able to do outside of going fully custom, is a Weapon-R intake that will cause more problems for your car and gain you no performance, a couple mufflers to add some exhaust sound and ruin how quiet it is.
About the only other stuff worthwhile might be suspension, but it'll be improved handling by way of sacrificing ride comfort.
If you want a performance car, the ES was the wrong car to buy.
I have seen a few ES ECU upgrades but have not tried any of them;
http://www.performancechiptuning.com/Lexus/ES/
http://www.gfchips.com/lexuses350.aspx
Hello,
OH i know the ES isn't a performance car, and i test drove a few GS350's and my impressions were mixed, One i test drove was fantasitic, very isolated but with tighter handleing and a bit 'faster', but then another that i tested may have had blown struts or something and did not ride well.
I'm quite happy with my car the way it is, but just like anything, (for me at least) i'm looking to see if there are any (sensible) improvments that can be made...nothing wrong with that i don't think.
I'll look into the ecu chips, i actually feel that the car is very fast it just takes for ever to shift into a lower gear...
Hello,
The trans does tend to hunt a bit; it's a tradeoff of having a 6spd auto. As nevernu said, you can put the trans into sport mode by pulling to the left once in drive, but also be aware this will hold your RPMs higher than normal and increase fuel consumption.
Which gen maxima? I ask because the 09+ models with paddle shifters shift really fast too.
Also, any older maximas (06 and older, IIRC) have a manual (cable) throttle and mechanical kickdown. The ES is all electronic. That's another hurdle to get over.
Hey, yep it was an older maxima, a 99 i think, very nice car. I've adjusted somewhat to using putting the shfter into S which seemes to cut the downshift time in half...so that help, and i really want i can shift manually and keep in in 2nd or 3rd i've learned so i'm in the power band then i merge.
However today was that first day i use it to drive into the city work for, and the isolation and ride was great!
