ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Extra Key remote required for my 2010 ES350
Old 05-11-13, 03:53 AM
smartways
smartways's Avatar
Default Extra Key remote required for my 2010 ES350
Hi
Can you suggest an online store to order an extra remote key for my 2010 ES350,
I've currently one key only and I'm afraid of losing it
I'll take care of the chip programming
Old 05-11-13, 07:12 AM
ThumperPup
ThumperPup's Avatar
check ebay you can usualy get them decent
i got one for my 07 for 59.00
Old 05-11-13, 11:05 AM
smartways
smartways's Avatar
Thanks for the help ,,,
can you let me know what you searched in ebay exactly ( what phrase did you use )
Old 05-11-13, 03:58 PM
garsarno
garsarno's Avatar
www.ebaymotors.com. Then enter remote key fob for 2007 Lexus ES350, many should show up in the parts and accessories section.
Old 05-11-13, 04:21 PM
ThumperPup
ThumperPup's Avatar
The op is looking for a 2010 not a 2007
also i think better for the OP to open the remote up and look at the numbers on the inside of the remote not that back but the inside then type those in on the ebay search option and it will come up with what is on ebay
Old 05-12-13, 06:01 AM
SICK350
SICK350's Avatar
Won't all 07 08 09 10 keys and transimiters work with a 2010 model?
Old 05-12-13, 06:02 AM
SICK350
SICK350's Avatar
Found this one on ebay.ca you might have more luck on ebay.com
http://www.ebay.ca/itm/07-08-09-10-E...#ht_6699wt_892
Old 05-13-13, 06:47 AM
jcat_350
jcat_350's Avatar
be very careful buying on ebay. Lots of the remotes will get to you and either not work at all or won't be able to be programmed to the car.
Old 05-13-13, 07:12 AM
ThumperPup
ThumperPup's Avatar
i think if the dealer tells you it won't be able to be reprogrammed to the car that just means there are not informed or not knowledgeable or just trying to get you to buy a new remote from them
I had a Dealer a month back i was told they can program a key if its been programmed to a car no problem
however depending on how many keys you have had they may need to do a Master reset of the key program
keep in mind one dealer says it can't be done just go and find another dealer see what they say
also get on your computer google locks smith lexus keys and other things find a lock smith just call around id be supprised if you didn't find anyone who can program a lexus key and even sell you one at less than the dealer
Old 05-14-13, 11:00 AM
jcat_350
jcat_350's Avatar
Whatever you say, guy.
Old 05-21-13, 08:40 PM
smartways
smartways's Avatar
Thanks guys for the help
Old 05-21-13, 08:44 PM
smartways
smartways's Avatar
Aren't the numbers inside the same as back side of the remote ?
the outside one starts with HYQ
actually there are tow numbers on the back side of the remote : one is FCC number and the other is IC number !!!
Old 05-21-13, 09:45 PM
ThumperPup
ThumperPup's Avatar
no they are not there is a set of numbers on the key's system board you never know someone might have had to replace the case at one time for the key and got somethign that didn't match the old one just becuase it was cheaper
just because the key's look alike doesn't mean they are the same all the time
Old 05-21-13, 10:27 PM
tinoleo
tinoleo's Avatar
the dealer gave me a price range: 350-450 usd (in san diego) and 30 min to set up. do you know where can make it cheaper?
Old 05-22-13, 07:08 AM
jcat_350
jcat_350's Avatar
that's about the going rate. You could try saving money by buying a remote elsewhere and hoping it can be programmed to your car properly, or see if a locksmith has the ability to program the key to the car as usually they'll charge less per hour of labor than the dealer will.
Quick Reply: Extra Key remote required for my 2010 ES350
