Rotor question
for a 2008 its
front...
(a) Using a micrometer, measure the disc thickness.
Standard thickness:
28.0 mm (1.102 in.)
Minimum thickness
25.0 mm (0.983 in.)
If the disc thickness is less than the minimum, replace the front disc.
rear....
Standard thickness:
10.0 mm (0.390 in.)
Minimum thickness
8.5 mm (0.334 in.)
If the disc thickness is less than the minimum, replace the rear disc.
front...
Standard thickness:
28.0 mm (1.102 in.)
Minimum thickness
25.0 mm (0.983 in.)
rear....
Standard thickness:
10.0 mm (0.390 in.)
Minimum thickness
8.5 mm (0.334 in.)
