ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
another after market audio question
Old 10-03-13, 08:26 AM
mlacomb
mlacomb's Avatar
To add specifics; my config on the LC2I makes the bass boost (Accubass I believe they call it) kick in at 37-38.
There are 3 pots on the face, and I believe one near the input. The three on the face adjust:
1. Bass output at low sound levels
2. Line output level (in case you're chaining amps, it has a line out too!)
3. Accubass level - boosts bass by this much when it hits the level below.
The pot near the input adjusts when the Accubass kicks in. The initial setting is "least sensitive" - and I found that to be right where the Lexus cuts out.
Of course, all of this will need tweaked to your liking, but my Accubass level is actually quite low - maybe 1/8 turn off of 0 on the dial? Just gives it enough of a kick at 38-40 - especially when I have windows and sunroof open, makes it sound like a much bigger system.
Old 10-08-13, 05:06 PM
rmv11
rmv11's Avatar
Originally Posted by mlacomb
Definitely grab an LC2I. You won't be sorry.
ive been looking around an answer to this, i have a 2nd gen IS non-ML, thing is, im about to change all but the HU, i will be running 3 amps in total. Do the lc8i do the work for me or i need something more expensive (I prefer not) like audiocontrol DQL-8, rockford 3sixty.2, etc etc. and if it is audiocontrol, is the acubass really necessary?
plz help!!!
Note: I will be powering 2 sundown sa 12 with a rockford 1500-1 bdcp, 4 rockford pps8-6 with a punch 1000-4, and another amp for the tweeters, thats why the signal processor has to be 6 or 8 channel.
Old 10-09-13, 07:08 AM
mlacomb
mlacomb's Avatar
I recommend the AudioControl devices highly, especially if you're building your system to play LOUDLY. Of course, I'm biased - it's the first and only line converter I've used, but it works well with the stock "premium" Lexus HU/amp combo.
Old 10-09-13, 12:16 PM
rmv11
rmv11's Avatar
Thanks for your reply, after a little bit of mooore searching i think i´ll go with the audiocontrol lcq1, it has everything an lc7i has plus equalization!
Dr. Jekyll
07-11-19 01:30 PM
trinivirus
IS F (2008-2014)
10-25-16 06:41 AM
Prinny
10-27-15 03:33 PM
GSLEX0586
10-26-10 07:31 PM
4GR-FSE
09-26-07 09:04 AM
Quick Reply: another after market audio question
