another after market audio question
ok, i got the sub and amp in today... but i believe there is a problem. i searched around the web but found no definitive answers.
hooked up my 12 inch obsidian audio and rockford 1000 amp. spliced off the front door speakers with hi/low converter because i also switched 8 inch sub to a pro audio mid range for added mid range on a separate amp and wanted full range inputs.
im having an issue where the bass sounds great at around 35 ( 8 speaker non ML ) but above that volume the bass doesn't increase, maybe even decreases. i messed with the gains, bass boost, and gains on the hi/low. something is telling me that the stock system has a bass roll off circuit and its causing my bass to suffer. has anyone had experience with this issue? and if so, if i use a separate hi/low to run off stock sub wires, will this still be the case? trying to find this out before i buy 100.00 dollar audiocontrol line driver. lastly, if i tap in to the wire before the amp, instead of the amplified signal, will that help? thx.....
There is variable EQ in the head unit. As you found out, at 35 on the volume **** you don't get any more bass. This is a safeguard so that average users don't blow speakers. This was the main reason I changed my head unit first.
Glad to be of help! I've found the lc2i does an EXCELLENT job of ramping up the poor output of the speaker outs too. The accubass is difficult to dial in; I've left my sensitivity at minimum though - kicks in around volume 38 depending on the source. I have a single 10" JL in a ported bass wedge run by a Rockford 500 watt amp. Bass level is slightly above mid, accubass is almost the whole way down but still kicks in hard. Let us know what you think! All other components for now in my car are stock (the base audio, non-nav.) I do plan on getting the front speakers upgraded, but do not plan on for now upgrading the amp - but the LC2I will allow me to do so effortlessly in this configuration if I want.
So, I have an Alpine MRX-V70 - it is a 5 channel amp.... will I need the LC2i, or will my speaker level inputs be good enough as input to the Alpine from the stock amp? I mean in terms of bass response, clarity, power use, etc. I have a stock deck also...
Probably will pipe in all the speaker level inputs into this amp and then run the speakers + my new sub directly.
Thanks!
Thanks!
Thanks!
Thanks!
Also, is there any way I can grab a pure signal from the OEM deck, or is it a digital signal?
Thanks
As you turn up the volume, the EQ (especially the low end) changes. This is to idiot proof the system so you won't fry the speakers. These devices restore that lost bass back into the system. It basically makes a factory radio work like an aftermarket one.
