"Check VSC system" only on startup goes off after.
Hi Guys,
I have a 2007 toyota camry 3.5 v6 2grfe a/t
with multi-info display and smart key with vsc.
Is this normal?
At initial startup "check vsc system" flashes(multi-info display) with red triangle "!" and dings once when I do this start procedure:
1. scroll through(push button switch to the "switch On mode" and wait for the abs,trac and airbag lights to go off..
2. then depress brake pedal,
3.then press the push start again for ENGINE START.
It NEVER flashes anything(warning or dings) when you directly step on the brake pedal then startup the engine..or pop up any warnings or lights when driving around.
Had it scanned and no error codes were found.
but upon reset, it did'nt flash anymore when doing the first procedure,
But it came back after a couple of days of driving.(flashes ONLY once again ON STARTUP and then no more)
also did the zero point calibration reset without any improvements.
Thanks in advance.
-GRiDY
Is this normal?
Thanks in advance.
-GRiDY
Redeemed07
08-15-18 11:26 AM
