Major Problem - Engine overheated and needs replacement
#181
The car overheated,though I didn't allow it to because I monitor the temperature gauge once it was over the half way mark,I switched off the Ac and parked. The reservoir is drained, I am waiting for the engine to cool of better I add water to get me home.Note I top up it up a bit this morning again.I ve had the thermostat removed if that affects in any way.I don't know at this point maybe I need to use a gasket sealant to remove doubts because I ve already changed water pump and even bought a new bigger radiator and am still dealing with this and also it mostly tends to overheat when it rains
TKnight96
ES - 5th Gen (2007-2012)
12-01-18 12:39 PM
kalki2020
35
01-02-17 11:19 AM
JamesT71
08-22-11 08:57 AM
