ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Measuring Brake Pad Thickness
Old 04-08-14, 02:02 PM
sf3r8z
sf3r8z's Avatar
Default Measuring Brake Pad Thickness
Can measuring pad thickness through the wheel opening without removing it give a close approximation? I'm 70 and no longer own a jack although I'm thinking about buying one for just this kind of problem. I'm going to a new mechanic and would like to know ahead of time that the work is really necessary if he says the pads have to be replaced.
Also if memory serves, worn brake pads do not require any work on rotors unless the pads are worn to the metal, right?
Old 04-08-14, 06:17 PM
RainaES350
RainaES350's Avatar
Just had my brakes done all-around last week ($600) and my guy removed the wheels beforehand to check them...I don't think it's possible any other way.
Rotors should always be turned when new pads are installed...at least enough to clean them up a bit or else you risk uneven wear and pedal modulation.
Old 04-08-14, 07:34 PM
nevernu
nevernu's Avatar
maybe this is useful for specs front and rear
File Type: pdf
File Type: pdf
Old 04-09-14, 02:39 PM
dman00001
dman00001's Avatar
I was wondering the same thing recently. Thanks for getting it asked and answered!
lexrally
RX - 1st Gen (1999-2003)
13
07-15-15 01:18 PM
hybridanim
Suspension and Brakes
04-05-11 05:22 PM
argh
02-08-07 09:43 PM
LexLS
Maintenance
10-23-03 12:46 PM
sxys_sc4
SC- 1st Gen (1992-2000)
12
10-12-02 02:01 AM
Quick Reply: Measuring Brake Pad Thickness
