ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
For a Smoother ride ?
Old 06-20-14, 11:28 PM
ThumperPup
ThumperPup's Avatar
Default For a Smoother ride ?
i am wondering
i know that i have new struts and that has helped the ride but now i realize i see and feel its a bit stiffer im guessing probably because the struts have less play since the old ones had almost 80k on them
I am wondering is there ever a recommended time that Control Arm bushings should be replaced ?
and am i correct in thinking that replacing the control arm bushings would give the ride a bit softer and smoother over bumps and cracks in the road ?
Or am i thinking about this wrong ?
Old 06-21-14, 06:05 AM
mlacomb
mlacomb's Avatar
As you replace parts, it'll return the ride to what was normal from the factory. Replacing the bushings will reduce play (similar to replacing the struts, but less so with the control arm bushings) and keep the car more stable in bumps, even if the ride seems harsher.
Ultimately, worn parts can make the car float and be more unpredictable in bumps and turns. I doubt your control arm bushings are worn to the point of needing replaced at 80k, but they'd need inspected to determine that. Mileage alone won't give a clear indication.
Old 06-21-14, 08:09 AM
ThumperPup
ThumperPup's Avatar
yeah i just picked the car up this morning
from the Dealer
had the Transmission service flush done
wanted to get it done when i still had 10k on the warranty in-case something does go wrong at-least they can't tell me i didn't keep up with proper maintenance of it
My Dealer Rep helps me out alot we are cool i paid 86 after the discounts he helped me with after taxes also for a trans fush at the lexus dealership
i asked about bushings and that stuff he said mine where looking great no issues with the car at all
wsaharem
Suspension and Brakes
04-05-19 04:51 PM
LexBrett
01-18-15 10:35 PM
Five1OH
02-22-09 08:09 PM
SuperCoupe400
06-20-07 10:21 AM
twizted
18
07-24-05 12:05 PM
Quick Reply: For a Smoother ride ?
