Gear Shift Light Burnt Out in 2007 ES
Can anyone share instruction and pictures or video on how to change the bulb in the gear shift panel of my 2007 ES
It's a pretty simple fix. First you start by removing the wood grain cover around your shifter by pulling straight up with some force, disconnect the cigarette lighter and ash tray light and set aside. Next remove the black piece that has park, neutral ect.. on it by lightly prying the 4 clips on the side. A clear plastic piece is attached to that black piece and needs to be removed, then unplug the light, replace and reinstall everything in reverse order. If I have time later I'll take apart mine and snap some pictures.
Good luck!
Good luck!
