ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
2008 ES350 timing case cover oil leak...
Old 10-01-14, 04:00 PM
AmongU
AmongU's Avatar
Default 2008 ES350 timing case cover oil leak...
Hi,
New to the forum. I have a 2008 es350 with 165k km (100k miles). Just into the dealer as I had a "check vsr" warning on the info panel. Turned out to be an O2 sensor ($393 installed plus $100 diagnostic). Also had the front rotors done & oil change. Tech noticed that there is some oil residue around the gasket on the timing case, said he will check next visit. Asked what it would cost to repair- approx $2300! (16 hrs labour). Anyone had experience with this? Any advice?
Thanks!
Old 10-01-14, 09:01 PM
chbow
chbow's Avatar
I just had a similar experience - went to the dealer 2 days ago for an oil change and afterwards they told me the "front timing cover was leaking oil" and it would cost more than $2600 to repair. I too would like to hear any info or advice anyone's got.
Old 10-05-14, 09:49 AM
SICK350
SICK350's Avatar
Same thing here in my 07, leak is very minor but annoying. After getting the leak I've lost a bit of interest in this car and decided it's my new winter beater with a slight oil leak. I also changed a bunch of o2 sensors and have had ignition coil on # 2 cylinder go twice now. I do all my own work usually but I don't think I can tackle this one.
Old 10-05-14, 06:37 PM
GCL
GCL's Avatar
Do you have a picture showing the location of where the oil is leaking?
It would help me to see if I (and others) have a similar problem.
Thanks.
Old 10-05-14, 09:55 PM
savon
savon's Avatar
It happened to my brand new 07 eight months after I bought it. Dealer repaired it under warranty. From what I read in this forum at that time, they need to remove the engine to repair it. True or not I don't know.
Old 10-23-14, 08:46 AM
igzy
igzy's Avatar
Yes, timing cover resealing is a major job and requires engine removal (huge cover and tight access). I would say leave it alone and keep an eye on the oil level so that you don't run it dry... Unless it is leaking profusely and then you may look into repairing it...
TomT127
RX - 3rd Gen (2010-2015)
191
06-13-24 03:20 PM
cl206
22
01-08-24 12:56 PM
duffer649
33
10-24-21 02:00 PM
heidihidin
08-22-18 11:05 PM
911s
12-27-15 12:31 PM
Quick Reply: 2008 ES350 timing case cover oil leak...
