ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Solution for Peeling Steering Wheel Controls for 07 - 09 ES350
Old 11-29-15, 04:14 PM
cwils71
cwils71's Avatar
Originally Posted by johncoby
I bought them too. They look cheesy but a HELL of a lot better than what I had. I still might just paint the damn things and get it over with.
This thread might be a better solution for the buttons.
https://www.clublexus.com/forums/es-5th-gen-2007-2012/590842-steering-button-2010-a.html
Old 11-29-15, 09:27 PM
Lexi66
Lexi66's Avatar
Originally Posted by croslinb
I’ve had the same problems as many others with the soft paint peeling off the steering wheel controls. $450 for the replacement part was ridiculous, so I tried several things which weren’t acceptable. Finally, I traced and documented the graphics and locations, then had a local vinyl wrap guy produce artwork and make some up. My wife is tickled pink with them although I’m not entirely happy. My question to you guys is, would it be worth $25 or $30 for two sets of these wraps? One set is to apply and screw up, the second is for when you’ve passed the learning curve. One of my problems is that I didn’t clean all the old paint off the one side and it’s outlines show through the vinyl. It can be seen in the photo. If there's any interest, I'll revise my art a skosh and try again.
Bob Croslin
rcroslin@tampabay.rr.com
1st attempt, but need to remove all the old paint underneath
Second attempt - a little better
Before
Does anyone know if this is a known defect on 2011 ES350?
Old 11-29-15, 09:43 PM
cwils71
cwils71's Avatar
I believe the 2010 - 2012 has actual buttons instead of the vinyl overlay covering (or whatever it is that peels off).
Old 01-30-17, 10:35 AM
alexulan
alexulan's Avatar
Default the best fix
It took almost 6 month of Ebay automated Search but i was able to score a 2010 steering wheel that had a good set of buttons and only set me back $90, this was due to a light tear in the leather of the wheel. Don't care.
The install was easy as pie just followed this guide:
1. Disconnect Car Battery.
2. Pop off two plastic covers and loosen two star screws.
3. Lift up Air Bag and Remove two more screws for the buttons themselves, Pry up gently the buttons to remove.
4. Install New buttons and connectors, dont forget ground wire to the bag.
5. Reverse steps 3 to 1 and Done!
DIYDaisy (05-29-17)
Old 01-30-17, 11:42 AM
ESh
ESh's Avatar
Received 1,010 Likes on 759 Posts
There's another way to save the color from peeling off - to spray the buttons with clear coat. It gets shiny but they would never peel. I did this and I like it.
Old 03-09-17, 04:24 PM
Farcus
Farcus's Avatar
Default Replaced Radio Controls
I have just completed replacing my peeling 2008 radio controls with Controls from a 2010. They work and look Great. Took me 30 minutes start to finish. I bought a wheel with the controls on ebay for $175.
Old 03-10-17, 12:24 AM
ESh
ESh's Avatar
Are they plug and play?
Old 03-10-17, 11:46 AM
Farcus
Farcus's Avatar
Yes, Just removed the old, and installed the 2010 set.
Old 05-29-17, 11:20 AM
DIYDaisy
DIYDaisy's Avatar
Default Rubber Breakdown
Has anyone tried this product? I am thinking about using the Rubberized paint from Auto Zone and just paint over the existing controls.
http://www.247skins.com/index.php?l=...t_detail&p=307
Lexus knows this is a quality control issue but they won't fix it.
2007 Lexus ES350 did get my melting dashboard fixed
Old 07-07-21, 03:17 PM
ryan1111
ryan1111's Avatar
Hi Bob,
I just bought some from https://www.controlbuttonrenu.com/lexus/
I wasn't able to get all the paint off and my buttons look like your first try. How did you remove the paint so well?
Thanks in advance for your reply!
Ryan
Bob Croslin
Before
LexusFan2
24
04-13-16 08:21 AM
tekkie
11-26-12 10:09 AM
panda327
10-20-08 08:52 AM
iKenn
11-16-07 12:17 PM
Quick Reply: Solution for Peeling Steering Wheel Controls for 07 - 09 ES350
