Fix - dim trunk light
The OEM trunk lighting is DISMAL.
Just an FYI, to get a LOT more light in the trunk, replace the bulb with a LED panel. The difference is like "night and day".
The LED panel just replaces the existing light bulb and has double-sided tape to stick to the underside of the trunk.
http://www.aliexpress.com/item/12v-P...557004091.html (picture for reference only. Buy it on eBay for about a buck!)
I actually wired 2 of these panels together, but using one panel is still a lot of light output.
If you ever find that you need brighter bulbs in your car I suggest vleds.com They have the brightest leds ive ever seen and more importantly they last.
I havnt had much luck with buying bulbs off ebay. As the ones I get have worse output and go out within a year. They are cheap though!
09-29-18 01:37 PM
CrackerJac
01-09-16 11:07 PM
VanCityLS4
05-21-15 10:37 AM
