ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Sunroof Glass Replacement 2009 ES350
Old 12-23-14, 09:40 AM
sunroofgla
sunroofgla's Avatar
Default Sunroof Glass Replacement 2009 ES350
I am needing to replace the Glass only on a 2009 ES350. Apparently the sunroof can be replaced without removing the headliner but I am not sure. I read one thread that said to take it to an automotive trim shop. I am hoping I can find the exact instructions such as what alldata provides and/or the contents of the factory repair manual for replacing the Sunroof glass. I have searched this forum and found three threads but not what I am looking for.
#sunroofglass
Old 12-23-14, 11:07 AM
nevernu
nevernu's Avatar
this is the standard sunroof? this is what the svc manual says, but not very informative
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 12-23-14, 04:01 PM
sunroofgla
sunroofgla's Avatar
Default Thank you nevernu
Thank you nevernu,
That information was better that I could get from alldata, at least from what I found.
I can't believe all the trim they say to remove to replace just the sunroof glass.
Well the sunroof glass can be found for $299 and it seems flat rate time is 4.5 hours.
I will study the pdf files and see what I can do with it before updating this thread.
Thank you very kindly, you have been very helpful.
Old 12-23-14, 05:10 PM
oldgrump
oldgrump's Avatar
I believe that you would only have to remove all the interior "stuff" if you are replacing/removing the "sliding roof housing" from the car. Thus, the title "SLIDING ROOF HOUSING: REMOVAL" of the second pdf. It looks to me like the glass removal is more like just steps 77 - 79 of that same pdf. I would sure check with someone who knows for sure before starting the job yourself.
Old 12-23-14, 10:06 PM
xanderES
xanderES's Avatar
You think its going to be a walk in the park eh? HAHAHAHA try it!
Do yourself a favor and pay to have it done. Otherwise I hope you are not working for 2-4 days, are meticulous in memory, and have removed panels before because thats how long it'll take to do it yourself. Also, you better hope you dont break any panels, clips, or miss putting back any screws either. On top of that you have to be VERY careful not to crease the headliner as it will be permanently deformed. You basically have to strip almost the entire interior of the car to be able to get it out. It is NOT easy.
If you got a quote from your dealership and think its going to take the ~4.5 they charge you, you are mistaken. They only charge that because no one would actually pay for the actual labor hrs it would cost. How do I know this? I talked it over with the service consultants and master tech after I did the job myself when I sound deadened the entire roof for my sound system install.
Old 12-31-14, 09:17 AM
sunroofgla
sunroofgla's Avatar
Smile Fixed: Total $360
Hi Guys and thanks for all your help.
I am sorry but I don't have any pics to post as I did not see the fix but here is what happened.
We bought the sunroof glass for 299 and got the entire frame and all from pick a part.
The junk yard installed it for only $60 for a total fix of 360.
It only took 20 minutes to replace the window so there is a very quick easy way to replace the glass.
I am sorry I can't post a discription/pics to help others out.
77. REMOVE SLIDING ROOF SIDE GARNISH LH
(a) Disengage the 5 claws and remove the sliding roof side garnish LH.
(See pic in 02.pdf in this same thread)
78. REMOVE SLIDING ROOF SIDE GARNISH RH
HINT: Use the same procedure for the RH side and the LH side.
79. REMOVE SLIDING ROOF GLASS SUB-ASSEMBLY
(a) Using a T25 "TORX" driver, remove the 4 screws and sliding roof glass sub-assembly.
Old 01-01-15, 05:06 PM
xanderES
xanderES's Avatar
Ah, I was under the impression that you were trying to change the whole or part of the actual assembly that bolts to the roof out. Which would of taken what I listed above.
You are indeed correct in the procedure if it was ONLY just the top glass part: Not the opening motor mechanism or the surrounding weatherstripping which people usually have problems with.
1 plastic piece on each side covers the screws and thats it.
Sorry for the misinformation but good on you for actually researching and resolving the issue yourself. We dont always get it right but we try lol
Lveyolfe
SC- 1st Gen (1992-2000)
06-15-16 08:19 PM
Lveyolfe
06-10-16 03:00 PM
Tsmith1982
04-29-14 11:51 AM
MJImport
08-25-08 03:27 PM
s6 4rings
06-26-07 07:08 PM
Quick Reply: Sunroof Glass Replacement 2009 ES350
