ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Older LiftMaster garage door program problems
Old 01-05-15, 04:25 PM
tocjonah
tocjonah's Avatar
Default Older LiftMaster garage door program problems
This is not a "homelink", in that the remotes are smart.
Typically, I just press the main button on the garage door motor, then press the button in the vehicle and voila it is programmed.
No luck on my 2008 ES350. I've erased the ES codes by holding buttons 1 & 3 for 20 seconds until I get the acknowledgment flash back from the vehicle,
Has anyone had luck programming their ES with an older LiftMaster+ without homelink?
Help! I've read everything on this forum and have not found a reference to the older remotes.
Old 01-05-15, 07:04 PM
nevernu
nevernu's Avatar
ive attached the svc manual pdf on encoding which may be helpful
File Type: pdf
TechNut
ES - 7th Gen (2019-present)
14
12-11-20 09:21 AM
TheLazyC
ES - 6th Gen (2013-2018)
12-22-15 08:19 PM
ayonnebay
10-22-14 06:31 PM
LXMN
14
05-19-09 07:25 AM
thj
06-30-06 04:53 AM
Quick Reply: Older LiftMaster garage door program problems
