How to remove the high mount third brake light?
My wife's 2010 ES 350 third brake light has an intermittent LED issue. The last 3 LEDs on the pass side flash on/off when the brake is depressed. My understanding is there may be a broken solder joint. My problem is I can't seem to get the assembly out. Does anyone know how the high mount assembly is mounted and how to remove it? I really need to try to fix it since a new assy. is over $400! Thanks
Thanks
Thanks for the info.
I managed to get the assembly out and to take it apart.
Apparently, the LEDs are operated in a gang of 4. One of the
LEDs failed in the 'open' mode.
This knocked out the other 3 in the bank.
I managed to solder a jumper around the open LED and put it back together.
It works, albeit with one LED out. Better than spending $400!
RX300Scott
RX - 1st Gen (1999-2003)
01-18-11 09:57 AM
