Climate control temp reading change
I've searched the forum high and low and haven't been able to find the solution to change C temp readings to F on my 2009 ES350. The car is Canadian and I'm in the US and although it's not a big deal I'd like to change it over. The importation company already changed over the speedo and so the cluster reads F degrees and Miles. Just that one last change to make it all match up.
I read an old thread on the earlier generation that the body control module needs to be changed. But, nothing on this generation. Lots of people trying to go metric from English so maybe we could even trade parts to make it happen.
Anyone with a definitive answer will be helping shed light on a much discussed topic.
I've checked with the Lexus dealer and it's not a programming change. At first I thought it would be the display, but due to a post here on an older Lexus the member found the PCM he replaced changed his temp setting. I'm interested in finding out the part for my 2009 ES350.
Thank you
Thank you
Dhabeck1
RX - 4th Gen (2016-2022)
31
12-03-23 10:49 PM
rjking2112
GX - 1st Gen (2003-2009)
42
03-18-19 05:42 AM
JayGoldste
HS 250h Model (2010-2012)
05-18-13 06:17 AM
