ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
DIY: 2007-2012 Lexus ES350 fuel filter change!
Old 09-14-15, 01:10 PM
ESh
ESh's Avatar
Default DIY: 2007-2012 Lexus ES350 fuel filter change!
Here is the DIY how to change the fuel filter on a 07-12 Lexus ES350. The fuel filter is located in the fuel tank.
1. Pull of the rear seat bench and remove it from the car.
2. There you will find this. Pop up the black rubber:
DIY: 2007-2012 Lexus ES350 fuel filter change!-t0wblif.jpg
2. Take a steel knife and try to separate the cover which is glued with silicone:
DIY: 2007-2012 Lexus ES350 fuel filter change!-he6kisl.jpg
3. Under the cover there is a plug. Remove it by pressing the clip:
DIY: 2007-2012 Lexus ES350 fuel filter change!-caet9wl.jpg
Now start the engine and let it run until it dies.
4. Now you need to remove the hose. First you need to slide the yellow clip and remove it completely:
DIY: 2007-2012 Lexus ES350 fuel filter change!-1sjael7.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-e7jzozc.jpg
5. Put a towel over the hole, grab the hose and pull it up:
DIY: 2007-2012 Lexus ES350 fuel filter change!-og3al9l.jpg
Because of the fuel pressure, some fuel may pour but the towel will "drink" it:
DIY: 2007-2012 Lexus ES350 fuel filter change!-lorxyro.jpg
6. Remove the towel and you'll see this:
DIY: 2007-2012 Lexus ES350 fuel filter change!-frebgo3.jpg
7. Now, with a 8mm socket remove all the bolts (8 of them):
DIY: 2007-2012 Lexus ES350 fuel filter change!-cr9wfij.jpg
8. Pull the whole unit. Look for the fuel sender, it's on the right:
9. This is where the unit goes. It's so clean because it's sorrounded by plastic walls and the dirt and water cannot get in there:
10. This is the unit:
DIY: 2007-2012 Lexus ES350 fuel filter change!-4uvzrzq.jpg
11. This is the fuel level sender or FLS. You need to remove the metal thing. Press on the white clip, turn the metal thing clockwise and pull:
DIY: 2007-2012 Lexus ES350 fuel filter change!-fmubl2g.jpg
12. Now, you have to remove the FLS. Just press it down:
DIY: 2007-2012 Lexus ES350 fuel filter change!-gwwirnl.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-baurtzs.jpg
13. This plastic holds the pump. Remove it, start with this holder:
DIY: 2007-2012 Lexus ES350 fuel filter change!-ntwwyyu.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-sjnkq37.jpg
14.Remove this piece of rubber and underneath it you will see the fuse that holds the FUEL STRAINER:
DIY: 2007-2012 Lexus ES350 fuel filter change!-q19y1dw.jpg
15. Take the knife and remove it:
DIY: 2007-2012 Lexus ES350 fuel filter change!-7nfj2d9.jpg
16. Remove the fuel pump connector, press the clip and separate it from the plug:
DIY: 2007-2012 Lexus ES350 fuel filter change!-t7prvrb.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-npyoiel.jpg
17. Remove the pump. Just pull:
DIY: 2007-2012 Lexus ES350 fuel filter change!-kwu0g25.jpg
18. The pump and the gasket:
DIY: 2007-2012 Lexus ES350 fuel filter change!-8inewyl.jpg
19. Remove the strainer:
DIY: 2007-2012 Lexus ES350 fuel filter change!-zwjrdwo.jpg
New vs. old:
DIY: 2007-2012 Lexus ES350 fuel filter change!-hzymgc1.jpg
Old 09-14-15, 01:11 PM
ESh
ESh's Avatar
20. Remove the fuel pressure regulator, just pull:
DIY: 2007-2012 Lexus ES350 fuel filter change!-fninose.jpg
21. Separation:
DIY: 2007-2012 Lexus ES350 fuel filter change!-9phecfq.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-0debkgg.jpg
New vs. old:
DIY: 2007-2012 Lexus ES350 fuel filter change!-fl7fllm.jpg
22. Take the FPR gasket from the old filter and put it on the new one:
DIY: 2007-2012 Lexus ES350 fuel filter change!-sinrob0.jpg
Press it down with the screwdriver:
DIY: 2007-2012 Lexus ES350 fuel filter change!-nwjwxyu.jpg
23. Now, the marriage. Align all the holders and press it down. Before you press it down, you have to make sure the fuel pump wires are placed on the right place:
DIY: 2007-2012 Lexus ES350 fuel filter change!-eyf0q3g.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-ozvzbnm.jpg
24. Put the FPR back in, just press it:
DIY: 2007-2012 Lexus ES350 fuel filter change!-4sbvdnb.jpg
25. Put the strainer on the right place and press it hard down:
DIY: 2007-2012 Lexus ES350 fuel filter change!-5hrenlt.jpg
26. Put the strainer fuse and press it:
DIY: 2007-2012 Lexus ES350 fuel filter change!-tl8fb3y.jpg
27. Now, the pump. Align it with the wires, plug the connector and press it down:
DIY: 2007-2012 Lexus ES350 fuel filter change!-b0zhltg.jpg
28. Put the rubber thing in the holder and put them back:
DIY: 2007-2012 Lexus ES350 fuel filter change!-0tnxcwc.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-kixmp84.jpg
29. Put the metal thing in the hole and turn it anti clockwise:
DIY: 2007-2012 Lexus ES350 fuel filter change!-pb4kazb.jpg
30. Clean the place where the hose goes, clean it with Q-tips:
DIY: 2007-2012 Lexus ES350 fuel filter change!-mcjviah.jpg
31. Put it back in the tank, return all 8 bolts, put the hose, the fuse and the connector:
DIY: 2007-2012 Lexus ES350 fuel filter change!-betcapq.jpg
DIY: 2007-2012 Lexus ES350 fuel filter change!-6g0yp1w.jpg
32. Cover the hole with a towel and start the engine. It will crank much longer than normal and it will run rough until it builds up the fuel pressure:
DIY: 2007-2012 Lexus ES350 fuel filter change!-ns0fr38.jpg
While it runs take a look at the towel, just in case if there's fuel leak.
Put the cover back, press it hard, put the rubber, the seat bench and call it a day.
33. This is how the filter look like:
DIY: 2007-2012 Lexus ES350 fuel filter change!-6srzkxf.jpg
34. Part numbers:
DIY: 2007-2012 Lexus ES350 fuel filter change!-66phyvv.jpg
The following 2 users liked this post by ESh:
Cjet (05-11-18), tawm (05-25-18)
Old 09-14-15, 08:27 PM
nevernu
nevernu's Avatar
great write up, why did you do this, was it running rough or...?
Old 09-15-15, 01:21 AM
ESh
ESh's Avatar
No, everything was OK with the car. The filter is small and I think 65000 miles is really enough on original filter.
Old 09-16-15, 11:05 AM
TLPLEXUS
TLPLEXUS's Avatar
First off, this is a great tutorial on how to do this from start to finish. Thank you very much for putting this together. Believe it or not, my car has over 150,000 miles and i don't think i have done that ever.
Quick validation question, is the fuel pump part of the same assembly? I am assuming that if my fuel pump ever goes out, i can follow your step to change it. But either case, it is a good idea to swap out the fuel filter since there is a finite life on it.
How long did it take you to do this from start to finish?
Old 09-16-15, 02:00 PM
ESh
ESh's Avatar
Yes, you can use this tutorial to replace the pump since it is part od the unit.
I would change the filter ASAP. 150000 is too much on factory filter, because it is too small.
I think it took me about 1 hour 30 minutes, but I lost so much time taking pictures.
Old 09-21-15, 08:37 PM
jfall
jfall's Avatar
Thank you very much for taking your time to do the write up and do such a great job of documenting it!
How much trouble was removing the rear bench? Once it was put back did it feel 'the same'?
Thanks again!
Old 09-22-15, 12:51 AM
ESh
ESh's Avatar
Thanks again!
No problem at all. It feels the same.
Old 12-30-16, 12:41 PM
kinny
kinny's Avatar
Thank You so much for this detailed work. It's invaluable to amateurs like me. So much money will be saved from the stealerships.
Your effort is not wasted.
Old 05-11-18, 10:12 PM
Cjet
Cjet's Avatar
Thanks! I will be replacing the filter and pump in the next few days. For those who want to download his excellent write up, I made a pdf of it here:
Old 05-12-18, 12:31 PM
jagtoes
jagtoes's Avatar
Great post. Nice job
Old 05-12-18, 04:01 PM
chuyrobles
chuyrobles's Avatar
Nicely done. I have over 200K and no fuel issues, yet. Never even done a fuel injection service. Every other oil change I run back-to-back bottles of Lucas or Techron injector cleaners. At the moment I'm more concerned about replacing the water pump. Will certainly keep this bookmarked. Thanks.
Old 05-13-18, 06:58 PM
ThumperPup
ThumperPup's Avatar
i have 197k on mine now never had the Fuel filter changed i do get fuel service done every 70k usually and run a bottle of techron every 10k and get about 28mpg steady on highway trips the way i figure this number out is by not trusting the computer readout i fill tank jump on highway continue my road trips and then fill up again when the dash says im at 1/4 tank of fuel left and then i take the miles dirrent by the gallons pumped and their i have my fuel MPG i also am rounding down i have in the past had times where i got as high as 31mpg using this method but usualy on 75% of the trips i take ill get 28.4 is what my math comes out to.
NdYAG (04-17-20)
sc4doubleO
Performance & Maintenance
32
11-09-18 11:06 AM
slickgt1
12-06-15 10:56 AM
saiko2j
GS - 1st Gen (1993-1997)
20
05-20-15 11:06 AM
LexBrett
04-23-15 10:33 AM
swhockey98
03-23-15 08:35 AM
Quick Reply: DIY: 2007-2012 Lexus ES350 fuel filter change!
