courtesy light (side door)
Hello, I am wanting to change courtesy light (the side door light) for all 4 sides. Right now is yellow ibut i would like it to be white. Would this fit in there ?
Another question I have is, you know when you approach the es350, the light turns on slightly at bottom of the side mirror? is it possible to change those to white led as well ?
Amazon.com: Cutequeen 10PCS LED Car Lights Bulb White T10 2835 4-SMD 80 Lumens 194 168 (pack of 10): Automotive
It is, I did that couple months ago. The only problem is you can break the mirror by putting the glass back. It is very tricky.
Thanks for that...I have a similar question in opposite turn.. "When you approach the ES 350, the light turns on slightly at bottom of the side mirror" Is this a standard feature on the ES 350 generation of peculiar to a certain year model?
I haven't had any problems with the remotes since converting most of the lights to LED. I did use high quality LED's. Most of these cars have multiple antenna/receivers for the remotes throughout the car. I wonder if you might have disconnected one of the wires. It the problem universal - doors, trunk, etc. or only at the driver's side?
May have found the culprit
Thanks guys. Universal problem. This projector LED was causing RF interference on FM. Pulled it and everything seems normal. Going to wait for a few days to see if my issues come back.
