Need Help With Engine Fault Code B2286
So I scanned my 09 ES 350 today and got a B2286 fault code from the BCM. Alldata says :
B2286
2GR-FE STARTING: SMART ACCESS SYSTEM WITH PUSH-BUTTON START: B2286: Runnable Signal Malfunction
DTC B2286 - Runnable Signal Malfunction
DESCRIPTION
This DTC is output when serial communication signals and CAN communication signals in the circuit between the main body ECU and ECM are inconsistent.
HINT: When the main body ECU is replaced with a new one and the negative (-) battery terminal is connected, the power source mode becomes the IG-ON mode. When the battery is removed and reinstalled, the power source mode that was selected when the battery was removed is restored.
Can someone please help me with this. What does this mean. I've gotten this code a few times.
B2286
DESCRIPTION
94esjag
10-27-09 12:06 PM
