ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
noise from rear wheel
Old 07-04-16, 04:39 AM
Rupi
Rupi's Avatar
Default noise from rear wheel
Had some noise from the rear of my 2007 es350. Got new tires but it still have the same. It starts after 120km/hr. It seems like some air hitting the wheel well. I really have no idea what it can be. Doesnt change the pace with speed. Its same constant weather car is at 120 or 140. Completely stops when car is under 120km/hr. If anybody have any idea. Thanx.
Old 07-04-16, 09:21 AM
Nutsplats
Nutsplats's Avatar
I think I got the same noise but mine is coming from the right front wheel well. It usually happens when I'm going a little faster. I think it's from a slightly loose wheel well cover / splash guard. I've noticed mine is a little loose. I'm going to get some new screws and push pins and give that a try.
Old 07-04-16, 06:58 PM
Rupi
Rupi's Avatar
^^ thanx for the reply. Today the noise started at 60km/hr and was much louder. Then it started at 40km/hr even louder. I felt that wheels gonna fly off as even the car was vibrating a lot. But Mine was easy fix. Lugnuts were loose. I didnt even thought about it untill i called the guy from where i got my tire. It doesnt make any helicopter sound now. But i will check the sound at 120 to 140. And will post about it that is it fixed or not. I was checking everything else.. wheel bearing, suspension, underbody etc. Didnt thought it could be tht simple. I also had mud splash guard loose. I fixed that too.
Old 07-06-16, 04:08 AM
Rupi
Rupi's Avatar
Still have some noise at exact 120 and above. It comes from rear of the car. Tires are new. It came with the old tires too. It is not continous so i dont think it is wheel bearing. Doesnt matter it is 120kmph or 140kmph but the sound pace is same. I checked the cover but it looks fine. Any idea.. anyone. Thanx.
Behemoth7
12-02-14 10:34 PM
oldManTan
Performance & Maintenance
75
11-12-14 03:24 PM
honasbone
10-14-14 02:02 PM
PdPThai
11-27-06 08:09 PM
TMaxxTim
Suspension and Brakes
04-07-05 01:25 PM
Quick Reply: noise from rear wheel
