2011 Lexus ES 350 recommend service after 120K?
Ya, It seems straight forward enough in many cases - when you can use tools to help you. I'm concerned about the tight space and the challenges of having to break a bearing free in that tight space. Don't really want to get started and realize I'm going to have to jack up the motor or ruin the pully and clutch to get it off the shaft. tx.
Hi PoorES - very useful post - Thanks. I saw that you suggested changing out AC clutch bearing. I recently changed the belt and the idler and tensioner pulleys. While the belt was off I found too much play in the AC clutch pulley, so I expect the bearing is nearly done. I wonder if you have replaced this bearing, or have any video links on DIY on an ES 350. Very little room in that area. Mine is a 2008 with 240KK's. Tx
Hayk, you're correct, I did misread the post - sorry for the confusion. Now I think, I probably have a bigger problem. I had an a/c clutch problem on an Infinity in my past, that I was able to ignore since I had moved to the cool West Coast. A bearing or a compressor change is another matter, unfortunately - probably $1k+ touch. Thanks for your keen attention and feedback. Cheers!
Hayk, you're correct, I did misread the post - sorry for the confusion. Now I think, I probably have a bigger problem. I had an a/c clutch problem on an Infinity in my past, that I was able to ignore since I had moved to the cool West Coast. An a/c bearing or a compressor change is another matter, unfortunately - probably $1k+ touch. Thanks for your keen attention and feedback. Cheers!
Hello gentlemen, how have you been? Looking back at my old post to refresh on the water pump for 2011 Lexus ES 350. This time I bought Aisin kit from Rock Auto which is a little bit cheaper. The car is 2000 miles shy from 200K miles total. Car ran smoothly with no leaks but preventative maintenance, I will perform the same job I did about 5 years ago. I have gain a lot of skill beside working my day job as Resp therapist… I feel pretty confident this time. Let me know
MNHWorld
CT 200h Model (2011-2017)
04-19-17 06:23 PM
Opex
ES - 5th Gen (2007-2012)
11-15-14 09:12 PM
