2011 es350 suspension
Recently traded 2000 LS400 for 2011 ES350. Has 60k and after traveling my normal work route realized the suspension has ton of body roll and very soft. Having had 2 rental vehicles recently the KIA optima and ford fusion, I am really disappointed in this ES. Reading up I find it appears to be the soft springs. Any recommendations on replacement springs or replace struts. Does anybody believe 60k is time to replace the struts?
Do some searching for posts by folks that installed Camry springs and stiffer aftermarket struts. I would also swap out the sway bars for Camry SE sway bars which are stiffer. That route may give you the most bang for your buck. Some have installed the Camry SE springs and struts.
here are a few recent threads. Here are links.
https://www.clublexus.com/forums/es-...-09-es350.html
https://www.clublexus.com/forums/es-...y-springs.html
https://www.clublexus.com/forums/es-...-es-350-a.html
albodan
ES - 5th Gen (2007-2012)
12-10-16 10:21 AM
