ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Wiper arm is touching the hood
Old 10-15-16, 05:25 PM
RookieLEX
RookieLEX's Avatar
Default Wiper arm is touching the hood
When I try to change my wiper blades the arm is touching the hood. I cannot even lift up the passenger side at all unless I open up the whole hood.
I have try to adjust the arms and move the blades up on the windshield, that fixed the hood clearance but when i sit inside the car it's in the way and when I turn the wipers on it wipes too far out and reach outside the windshield. I notice the arm section with the spring does not sit on the windshield flush. i have try to tighten the 14mm bolt while holding the arm down but still no luck.
Attached Thumbnails Wiper arm is touching the hood-photo774.jpg   Wiper arm is touching the hood-photo952.jpg   Wiper arm is touching the hood-photo189.jpg   Wiper arm is touching the hood-photo427.jpg   Wiper arm is touching the hood-photo165.jpg
Old 10-15-16, 05:55 PM
jagtoes
jagtoes's Avatar
In order to change the blades you need to open the hood.
Old 10-15-16, 06:37 PM
RookieLEX
RookieLEX's Avatar
So the arm touching the hood is normal too?
Along with passenger side not able to lift up?
Old 10-15-16, 08:22 PM
mlacomb
mlacomb's Avatar
I just fire up the wipers, then shut the car off when they're in a good spot... never thought about opening the hood
Old 10-16-16, 05:31 AM
jagtoes
jagtoes's Avatar
Yes that is the way it is designed.
Old 10-16-16, 05:59 AM
RookieLEX
RookieLEX's Avatar
I don't think it's normal. Not sure if you see the close up pic but because of this I have paint chips on the hood.
I have changed wiper blades on many cars (lifting the blades on a 90 degree angle) before and this is the only one that require to open the hood to do it.
Old 10-16-16, 08:03 AM
jagtoes
jagtoes's Avatar
Our kids Audi A4 and our Jaguar all require the hood to be raised to change the blades . Other cars have also partially covered the lower part of the wiper arm with the hood. If the wiper arm is actually touching the hood then there is a problem where either someone tried to lift the arm and chipped the paint or the hood is mis-aligned. There should be around 1/8" clearance between the arm and the hood. If it is touching then someone did something to make that happen. I have also seen some cars that have a "park" position in order to change the blades.
Old 10-16-16, 08:07 AM
jagtoes
jagtoes's Avatar
OK looking at the picture I can see where someone improperly lifted the arm and chipped the paint. Clearly the incorrect way to replace the blades and the results have shown the damage. Operator error.
Old 10-17-16, 03:40 AM
codejd
codejd's Avatar
Or just put them into winter-mode first.
Old 10-17-16, 06:35 AM
LexBob2
LexBob2's Avatar
When I had my ES350's that's what I did.
Old 10-17-16, 07:09 AM
RookieLEX
RookieLEX's Avatar
I guess from now in I either pop the hood or turn the wiper on half way up and turn car off right away to install new wiper blades.
Old 10-18-16, 02:54 AM
codejd
codejd's Avatar
In case you don't have the manual, go online and download a PDF as it is very helpful;
2008 ES350 Manual
On page 170, it explains what I (and LexBob2) were talking about;
Old 10-18-16, 02:11 PM
nguyent8
nguyent8's Avatar
Thank codejd, it's very helpful. Makes sense that we don't need to open up the hood to clear out snow
Old 10-19-16, 03:20 AM
codejd
codejd's Avatar
Sure. It's also very helpful to leave them in that position during the winter as your windshield defrost will work better, melting the snow/ice from your blades so you don't have to knock them with a scraper or whatever.
N3441S
ES - 6th Gen (2013-2018)
12-27-17 09:47 AM
ProfesrLEX
05-23-16 08:27 AM
akshunj
12-29-15 05:43 PM
Blueshark
12
01-05-10 05:37 PM
iStyle
05-16-07 08:23 AM
Quick Reply: Wiper arm is touching the hood
