ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Check Eng light on/Check VSC on display/traction light on
Old 03-18-17, 07:30 PM
NINAPOO24
NINAPOO24's Avatar
Default Check Eng light on/Check VSC on display/traction light on
Good Evening all,
Was driving this evening with the wife and out of nowhere all of these warning lights started coming on. The check engine light came on, check VSC came on the display area, and what appears to the indicator for the traction control was lit up. Not to sure what this means in terms of what happened, why it happened and what the costs may be to repair. Any information and guidance/insight would be greatly appreciated.
Thomas
Old 03-19-17, 05:14 PM
ESh
ESh's Avatar
Originally Posted by NINAPOO24
Good Evening all,
Thomas
you need to pull the codes first.
Old 03-19-17, 11:27 PM
acheuk
acheuk's Avatar
Have you brought it to service or repair just before this happened?
Yes, you'll need to pull the code first. Hopefully it's something like a speed sensor that's easy to fix.
Old 04-02-17, 04:16 PM
marvinje
marvinje's Avatar
Good Evening all,
Thomas
Had the same issue, I went to Advanced Auto Parts and they pulled the codes, I had an ignition coil go bad.
GenoG
12-01-21 01:57 PM
Darkman67
09-25-14 06:36 AM
kchow510
01-22-13 04:52 PM
larryd2609
RX - 1st Gen (1999-2003)
12-20-11 01:46 PM
D.Steezy
07-03-09 12:30 AM
Quick Reply: Check Eng light on/Check VSC on display/traction light on
