ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Coolant temp gauge monitoring system??
Old 04-28-17, 04:55 PM
nevernu
nevernu's Avatar
Default Coolant temp gauge monitoring system??
Has any DIYer devised a decent monitoring system for coolant? Yeah I know the normal gauge is there but I'm thinking of something flashing when the temp gauge reading is outside certain parameters. Come on peeps here is a business opportunity!!! I know I'd buy one
Old 04-28-17, 07:23 PM
jagtoes
jagtoes's Avatar
If you don't scan your gauge during normal driving you probably shouldn't be driving. You already have 2 warnings , one being the gauge and the other being the over temp light. It doesn't take to many smarts to read them.
Old 04-28-17, 08:39 PM
nevernu
nevernu's Avatar
yeah I guess you are right sorry to bother you.
Old 06-07-17, 10:27 AM
teigen
teigen's Avatar
Hello nevernu-
I too like to monitor my temps (and other things) a bit closer. I highly recommend an Ultraguage device (google it). Well worth the money. It reads all information from your OBD port. I have mine mounted right to the dash, so a quick glance will show the exact temp, rpm, mpg, etc.
The also sell cheaper OBD port devices that you can then connect to your phone and use your phone to display these types of details. However, I like that the Ultraguage is a fixed permanent item and therefore do not need to remove my phone each time.
Hope this information helps, best of luck!
nevernu (06-07-17)
Old 06-07-17, 10:51 AM
nevernu
nevernu's Avatar
wow I'll have a good read of everything this can do
Old 06-07-17, 07:12 PM
jagtoes
jagtoes's Avatar
There is an app called Torque Pro that provides the same info. All you need is an ELM 327 OBDII port adapter for $10 and the app cost about the same. It give you all of the info that the OBDII port puts out.
nevernu (06-07-17)
Old 06-07-17, 10:04 PM
chuyrobles
chuyrobles's Avatar
Not a bad idea, especially in cars with new drivers, but many folks simply don't get in the routine of scanning their gauges.
You got me looking in the web for what's out there. Found these:
http://enginewatchdog.com/index.html
Amazon Amazon
http://www.gowesty.com/product-details.php?id=24196
http://www.speedhut.com/gauge/GR-WTR...FURqfgodxGgDMA
http://www.instructables.com/id/Car-...erature-Alarm/
http://www.jegs.com/i/Longacre-Racin...FceXfgod8m8OBQ
Old 06-09-17, 04:12 AM
jagtoes
jagtoes's Avatar
[QUOTE=chuyrobles;9890820]Not a bad idea, especially in cars with new drivers, but many folks simply don't get in the routine of scanning their gauges.
If this is the case then there will be a lot of idiots who will run out of gas.
Old 06-09-17, 11:10 AM
teigen
teigen's Avatar
I have never regretted spending the money for my Ultraguage, I have used it on numerous other vehicles for friends/family to help diagnose issues, codes, clear check engine lights, etc.
If you have a car without fuel consumption monitoring (i.e. MPG indicators) it also provides numerous screens for monitoring your gas mileage for trips, instant consumption, between fill-ups, etc.
jennypenny
04-03-19 10:30 PM
lexus-is2
04-17-14 01:36 PM
MValentine
09-07-13 02:10 AM
lexus-is2
07-16-13 01:35 PM
mjes300
08-05-09 05:40 PM
Quick Reply: Coolant temp gauge monitoring system??
