Passenger airbag code 1650
4th Gear
Greetings from a new club member. I just purchased a 2007 ES350 in really great shape, except for the passenger side airbag/ SRS light which indicates an error. OBD says only one code: “B1650” which means an “occupant Classification system malfunction”. I tried to erase the code several times with the scanner, and each time the error light instantly returned, so there is an obvious problem. It would be nice to avoid the stealership and fix it myself. Has anyone had success in fixing this problem, or have any tips to figure this out? Thank you in advance.
Greetings from a new club member. I just purchased a 2007 ES350 in really great shape, except for the passenger side airbag/ SRS light which indicates an error. OBD says only one code: “B1650” which means an “occupant Classification system malfunction”. I tried to erase the code several times with the scanner, and each time the error light instantly returned, so there is an obvious problem. It would be nice to avoid the dealership and fix it myself. Has anyone had success in fixing this problem, or have any tips to figure this out? Thank you in advance.
there also is a big recall campaign going on with the passenger side airbag there might be something wrong or perhaps who ever owned it before you might have disconnected that airbag because the recall wasn't able to be completed but now your in CA and being in California means that is a zone A Car if they haven't completed the recall yet then take it to a dealer and have them complete the recall if they have perhaps they did something wrong, and it got damaged during the recall repair
