no control of my temperature climate controls in my 07 es350.
The other day I started the car and turned a/c on...then the temperature control panel went blank, the air bag light came on and hot air started blowing. I had no control of temperature climate controls and could not get hot air to stop blowing. I mean the screen is totally blank, but hot air is blowing out of the fan.
After checking driver's side fuse and under the hood, the hot air stopped blowing but there is still no control of the temperature panel. As far as I can tell no fuse were blown. Though not sure exactly which fuses I should be checking.....
Can anyone please advise as to what might be the issue?...
Thanks Phil
Thanks Phil
Phil,
I am not a mechanic, nor an electronics specialist. I'm sure others here will have more useful advise. However, it seems to me that if the system is blowing at all, your problem isn't a fuse. If I had the skill, I'd be checking for switches, not fuses. However, it were me, I'd be getting some help from a mechanic, even if it had to be at the dealership.
Good luck. Sounds like a P.I.A.
IloveLexus
06-22-10 12:44 PM
BXBomber
Performance & Maintenance
05-09-10 05:25 PM
