Changing the battery in 2012, ES 350
I need to change the battery in my 2012, ES 350. I would like to know if I need to keep a separate constant charge on the system while the car battery is not connected. What happens if I do not keep a charge on the system?
Thanks Ed
Thanks Ed
You could lose the memory in some things: ECM, clock, radio, etc.. You can buy a battery saver device that uses a 9-volt battery and plugs in cig lighter. I don't mind resetting everything, but ...
https://smile.amazon.com/Powerbuilt-...ory+saver+tool
JMJS49
ES - 5th Gen (2007-2012)
13
06-06-14 08:36 AM
