Wet rear carpet
looking for help and advice about my passenger siide rear carpet being wet. Only the rear passenger side, is it from the sunroof? I would appreciate any insight. Thanks
I would have someone go with you to a touchless car wash and you sit in the back and check for leaks . If it were the sun roof you should see water stains on the headliner. Make sure the carpet is dry . Also check the rear door seals and see if you see any traces of water. Take a piece of note paper and hold it at the door seal and close the door. Pull out the paper and it should resist as you drag it out. Do this all around the window. If you find nothing then you may need to pull the door sill plate and also look under the car for holes. You may want to also check if there is a AC drain in the AC vent area that is plugged and spilling condensation on the floor.
Benjune
06-02-11 08:28 PM
