ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Belt Tensioner Replacement ES350
Old 09-10-17, 03:25 AM
ednmoore
6th Gear
ednmoore's Avatar
Question Belt Tensioner Replacement ES350
Hi, I think I need to replace the belt tensioner on my 2009 ES350. It looks like I'll need to remove the A/C compressor to access the bolts for the tensioner. Can anyone tell me if this is correct. Any suggestions on this repair would be appreciated.
Old 09-10-17, 09:01 AM
nevernu
nevernu's Avatar
Maybe there is something here useful. Note on reinstall the bolt lengths and torque value
File Type: pdf
File Type: pdf
File Type: pdf
ednmoore (09-13-17)
Old 09-11-17, 01:41 AM
chuyrobles
chuyrobles's Avatar
If you have a squeaky pulley bearing, I'm pretty sure the bearing itself can be replaced. Did it on my Tacoma and 'the book' also calls for replacing the entire tensioner assembly. Wouldn't be surprised if they used the same bearing size.
ednmoore (09-13-17)
Old 09-13-17, 04:58 PM
ednmoore
6th Gear
ednmoore's Avatar
Thanks for the suggestion. I've already replaced all the idler pulleys. I also replaced the water pump. It was definitely bad, but not the source of this squeak. I'm starting to think the belt (new) needs more tension, or it is one of the major components (alternator, etc).
Old 09-13-17, 05:00 PM
ednmoore
6th Gear
ednmoore's Avatar
I did not see exactly what I was looking for in these diagrams, but they are definitely nice to have on hand.
Old 09-13-17, 07:08 PM
Blueshark
Blueshark's Avatar
My god, you may have the same problem than i, last year, did all that and finally, it was the alternator that was emitting the squeal noise.
ES350 2008
Old 09-14-17, 05:44 AM
ednmoore
6th Gear
ednmoore's Avatar
ES350 2008
Thanks for the comment. The alternator was my next guess. I have not been successful in isolating where the sound is coming from...
Old 09-17-17, 04:22 PM
ednmoore
6th Gear
ednmoore's Avatar
It turn out the alternator was the source of the squeaking and chirping noise. I replaced the alternator and it sounds good as new now. I'm disappointed that the alternator needed replacing with only 86k miles on the car.
Old 09-18-17, 03:13 AM
ESh
ESh's Avatar
Received 1,040 Likes on 774 Posts
It was the decoupler pulley, not the alternator.
NdYAG (09-23-18)
Old 09-19-17, 02:30 AM
ednmoore
6th Gear
ednmoore's Avatar
Hi, thanks for the post, because I did not know what a decoupler pulley was until you posted this. Can you be 100% certain it is the pulley and not a bearing inside the alternator? Interestingly, the price of the decoupler pulley looks to be almost 1/2 of the price of a complete replacement of the alternator (rebuilt) at my local parts store. Do you need any special tools to replace them?
Old 09-25-17, 01:33 AM
chuyrobles
chuyrobles's Avatar
Gates sells decoupler pulleys for ES350 for $47, # 370026P. You do need a special tool; they average $25. Our decoupler pulley seized at about 120K and fried the alternator. Gates recommends replacing the pulley at 100K. The Lexus service maintenance schedule doesn't even mention the pulley - bad Lexus...
http://www.gates.com/products/automo...er-pulleys-adp
igzy (09-21-18)
Old 09-21-18, 01:02 AM
Jumbojoe55
Jumbojoe55's Avatar
I believe that my alternator decoupler pulley is starting to make noise too. I replaced the belt with a gator back and sprayed my pulleys and belt with Aerospace 303 protectant. The noise improved, but it comes back after going out on a drive. Usually only hear it coming to a stop and when I park at the end of the drive.
Has anyone removed the alternator pulley? Can you remove it where it is or do you need to pull the alternator out?
Old 09-21-18, 06:26 AM
igzy
igzy's Avatar
This is good info, thanks! Would you know what adapter is needed? My guess looking at the photos would be H17xH19 or H21xH28
Old 09-22-18, 04:04 AM
chuyrobles
chuyrobles's Avatar
I don't know the size of the OEM decoupler pulley, but the Gates replacement is 37026P and the tool to service it is 91024-3, which is an H17xH19. I would assume they use the same tool. You can find $25 kits with this tool on Amazon.
igzy (09-24-18)
Old 09-22-18, 04:19 AM
chuyrobles
chuyrobles's Avatar
This Gates video appears to show a Toyota alternator as their model for testing and replacing the decoupler pulley.
Quick Reply: Belt Tensioner Replacement ES350
