09 motor mounts
09 motor mounts
Guys, I知 searching and keep coming out empty handed. I知 trying to fine some info on all the mounts on this car. I知 sure they need to be replaced and I壇 like to do them myself. I壇 appreciate any help. Thanks!
12372-31010 - Driver side
12361-31170 - Front engine
12362-31040 - Passenger side
12363-0P141 - Strut Rod, aka dog bone; goes on top, passenger side
The front mount I could not find aftermarket. Got it on eBay for $90. That one the the strut rod are the only two I've replaced. I have the other ones (Anchor, I believe) but have not installed those. The front is relatively easy to install but you need a jack under the engine to help line up the bolt holes. The driver and passenger mounts look like you need to lift the engine quite a bit to clear the bolts pressed into the mounts.
lexbubba90
06-11-14 08:36 PM
pbbnxiltae
11-10-07 06:34 AM
