Coolant Leak- $1,000 to repair
I took car to shop because of check engine light. Learned I have a coolant leak. Will cost approx. $1,000 to replace coolant gasket and sealant. The parts are fairly inexpensive but the labor time is almost 6 hours. That seems excessive to replace gaskets and sealant. Is this normal?
Repairs at the dealership will in nearly all cases be considerably higher than at a good independent shop or even a Toyota dealership. It might pay to check out other options vs. the dealership.
I understand the dealer charges more. Wanting to know if 6 hours is a reasonable amount of time to repair the leak.
Not certain what is causing the leak. The 6 hours of labor time is to replace the coolant gasket, sealant, cleaning, etc.
That doesn't include thermostat or water pump as it's not clear if they are the source of the leak.
They are not including the thermostat and water pump in the 6 hours. They don't think i need a water pump at this moment and won't know if i need the thermostat until they do the gaskets, sealant, and clean things up. This is what they are telling me. The parts are about $250 and the remaining amount is the labor- for the 6 hours. 6 hours seems a bit much for these items but i'm not sure so wanted to ask all of you. I will be talking to them again on Monday and hoping to be more informed after hearing from this forum
Car didn’t overheat. The coolant is leaking. You can see it on the engine. When they took it apart they discovered it’s actually the head gasket which is now major repair.
TyneeGX
GX - 1st Gen (2003-2009)
15
03-25-22 07:01 PM
sgmstr
02-02-14 11:25 AM
