Disable Seat Belt Alarm on 2011 ES350
Initially I had the stealership disable the chime noise but since have used the Carista app for this. I bought an extra male seatbelt end to get rid of the flashing light.
I have to unhook my seat belt to reach the gate sensor on a 6 story parking garage. My spot is on a higher floor and I would prefer not to re hook it.
There's an IS thread about this and someone says this procedure worked on a 2010 ES. I'm not sure it'll work on your 2011 or if you're already aware of this. You might try it to see if it works.
1. turn the key to the ON position which means pressing the start button twice on the new IS since it doesn't has the key, foot off the brake
2. Press the trip reset button couple of times until the ODO is displayed (not trip A or B)
3. turn the ignition to the LOCK (OFF) position
4. unbuckle the driver's seatbelt if it was buckled.
5. turn the key to the ON position again press the start button twice. when the dash lights comes on, press and hold the trip reset button and count a slow 12 seconds. (editor's note, hold it more like 30 sec)
6. while still holding the trip reset button, buckle the driver's side seatbelt.
7.and the odometer display should read "b ON" or "b OFF". toggle the beep OFF with the trip reset.
8. the process should be completed when you unbuckle or turn the key off.
From what I've read, this doesn't totally get rid of the seat belt chime... only the obnoxious quick chiming you get if you don't buckle the seat belt.
I haven't taken a drive yet as it's too late, so haven't tested it out. I can tell you that when I turned the car off, and then on again, I still got the initial seat belt warning chimes. And, as I've read, this only disables the obnoxious quick chimes you get when you get up to a certain speed. After I test tomorrow, I'll post an update. Then again, if you happen to get it working, I guess you'll find out for yourself.
catsnmusic
05-05-15 07:03 AM
KennethJ
RX - 3rd Gen (2010-2015)
01-05-13 04:06 PM
