Bought used steering column after install tried to insert key got message "Key Different"
Is it possible to reprogram it
What should I do?
Thank
Leng
If I remember correctly there is a bunch of immobilizers in the steering column you have to find them and switch everything from your old one to the new one.
Lexus did the install and are saying my there’s nothing that can make it work. The used steering column assembly actuator and multiplex won’t connect to test of the car because it’s already programmed and can’t be reprogrammed. It’s a 2007 es350 so it’s a push start. Does that make a difference.
You would be better off in the es section, your es could have 18 different things that the ls does not have. I have 0 knowledge on the es platform sorry best of luck.
