Es 350 issues
Es 350 issues
About 5 months ago, I bought a 2012 es 350 with 74k miles, purchased the gold extended warranty. Drives like a dream.
took it to the dealership for my first first oil change and 80k maintenance (early). Got the car back, drove out of town 3 hours away, on the way back, check engine light comes while doing 80 mph, heat stops working then it dies.
get it towed the dealership, they tell me it overheated, no coolant. I don't understand, b/c it was just at the dealership 2 days prior. I'm pissed, more than likely the engine is toast, and I'm still waiting for info from the warranty company. They want the engine torn down a little more to see exactly where the leak is.
WTF!
WTF!
Happened to me around 80k miles a few years ago. Was driving in heavy traffic on a surface street and saw a wisp of steam, looked down at the temp gage and it was towards the H. Quickly pulled over and shut off the car. I think these ES water pumps fail fairly quickly and having to constantly look at the gage is not a reasonable requirement to drive the car.
Luckily I didn't sustain any engine damage that I have been aware of, but if I had been on the interstate I am afraid it might have killed the engine.
WTF!
WTF!
Regardless- good luck. The ES is otherwise a wonderful automobile . . .I'm on my 4th one.
If you can't see your water temp gauge when you glance at your speedometer then you get what you got. Do you check your fuel gauge or just wait until you run out of gas. Maybe the auto mfg's should send you a text or put it on FB when the WT gets to hot.
when you drive do you watch the dashboard or the road? So it's my fault that the radiator wasnt working properly when i just got it back from the dealer with an all clear? No reason to be an ***!
Water temp is something I watch religiously on all my cars, even now... just force of habit since the old days of my '67 Chevelle overheating. Back then we only had water in the radiator. I have to admit I wouldn't think a car that just got serviced would go through this, so I wouldn't expect it for sure. Huge bummer! I wonder why the dealer didn't catch something then, or did something just happen to fail coincidentally right after. In any case, good luck. I hope this gold warranty will cover the expense of repair.
Driver error . When was the last time you checked your fluids prior to the 80 mph excursion. They usually put instruments so people could read them. So if you were sharp enough to read your speedometer then you should have seen your water temperature. Good luck
According to your post they only changed the oil. You failed to mention if they checked the other fluids such as the PS , Brake and coolant. You might want to reread your post. For future reference if the little needle in the water temperature gauge moves past the half way mark (that's right of it) then you are starting to have a problem and should pull off the road and check the cause. Check all of your fluids once a week . Good luck
You should read before you criticize, it specifically states 80k maintenance. I know how to drive and operate a vehicle. Since you know everything and want to tell me what I didn't do, what did I do to make the radiator fail and leak?
