Can someone help me out please
I have a 2007 Lexus ES 350 what about a hundred twenty five thousand miles on it I recently changed my CV axles control arms shocks and struts gave it a tune up when I'm driving doing 40mph to 50 mph if I let go of the gas pedal and hit the gas pedal again it's a real bad shutter or shake that is coming through the steering wheel and being felt even on the passenger the problem started occurring about a month ago and there's no check engine light on or any codes that come up is anyone else experience these problems what there Lexus please let me know
thanks and have a great day
Check the dog bone engine mount
if I'm doing 45 miles per hour and I take my foot off the gas pedal and then press The Gas Pedal it's like a shutter or Shake I might just have to bring it to Lexus
So, the shutter existed before you replaced all those suspension parts? If so, did the shutter change in any way from before? Our 07 ES359 had a similar vibration at those same speeds. However, the vibration would not manifest under hard acceleration. The difference with your shutter is that I didnt have to lift the gas pedal to cause the vibration. The cause of the vibration was a worn out passenger-side CV axle. In your case, I next would suspecr a wrapped brake rotor, sticking calipers, or damaged brake pads.
CarZact (06-06-18)
What!? I find that hard to believe. Shuddering is a symptom of a bad converter but it is not a known issue with the ES350. I would continue driving it to see if the condition worsens; you really have nothing to lose if you are going to rebuild/replace the tranny anyways. I would replace the ATF filter - the filter in the ES350 is a felt material type, which are more likely to clog than the mesh types. A clogged filter could cause shifting issues. I went with Beck Arnley # 044-0356. When I replaced the OEM filter at about 120K, the filter was quite black and dirty.
I would not throw anymore parts at this car until a knowledgeable person looks at it (and the papertrail, if it exists). It's also difficult to determine what was done to your car and in what order from your posts. Was the vibration on acceleration the initial reason for the listed work done to the car? Did you or someone else accomplish the work on your car?
jack4010
UX Models (2019-present)
13
10-27-20 06:19 AM
Rob Daman
GX - 1st Gen (2003-2009)
08-18-08 02:20 PM
